Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
Resolved Resolved by Rich!
Help With Variable Input And Output For Faces
Well, I was working on a surprise for the group, but I need some help first. I have a nifty multiple face detection program working in C#.net. So far I have it programmed to recognize my face, DJ Sures, Sarah Connor and Alan Turing. Minus my face, I figure all EZ-robots should know who the other three people are.
My C# app generates a change in variable and displays this in a label in the form to show who's name it is for the face it sees. For this to be useful for integration with ARC I need to get this variable out of my app an into ARC.
I see two ways to do this, one is write the data to a .txt file, have ARC keep checking this text file, read the text file, if the text changes then act on that. - This seems sloppy and slow.
Option 2 seems better which is to use TCP/IP and Telnet. I've viewed the tutorial here: https://synthiam.com/Tutorials/Help.aspx?id=159 and I fundamental understand it. I can connect to ARC with Telnet. I I'm sure I can tell my C# app to send telnet data. What I can't wrap my head around is how to I make a script in ARC to look for an incoming variable on the TCP/IP port such as "$Face_Name" so that ARC can then act on that data?
Can someone help me with that? Or is there a 3rd option I'm not thinking of yet that would be better? I'm looking forward to get this figured out so I can share my app with the group.
Thank you! -Justin
Absolutely Awesome ,
I think everyone has been thinking about when something like this would be here...
Cant wait to play with it.
Still waiting for my Roli to be shipped , but will have a play on ARC to get familiar with it.
Hais.
#19
wow! very cool. can't wait to see how it works!
