Custom Movement Panel V2 icon Custom Movement Panel V2 — Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives Try it →
Try removing the EZ-B from the list of connected devices under your bluetooth management, power off your EZ-B. Replug power in and re-pair the EZ-B look at the com ports added and use the lower com as I am sure you know then try reconnecting.
