Omron HVC-P icon Omron HVC-P — Omron HVC-P ARC plugin: real-time body, hand, face, gaze, gender, age, expression and eye estimation; facial recognition via Omron software Try it →
What robot are you using? A custom bot or Roli?
Russia
? ????????? EZ-B v4 WiFi Robot Controller
How is it set up? Are you using a H-Bridge? Did you follow any H-Bridge tutorial? Have you checked you have the correct ports set up in the config?
We need a lot more information than you have provided in order to be able to help you.
If it is a H-Bridge, follow my H-Bridge tutorial, it tells you exactly what you need to do if Movement Panel directions don't correspond with actual robot movements.
If your using a modified servo setup, there may be something wrong with your scripting.
If your using an h-bridge and electric motors, please follow the link that Rich posted to his h-bridge tutorial.
