Python Native icon Python Native — Run real CPython in ARC with full package support, camera access, ARC APIs, and bidirectional robot control. Try it →
Hi, I purchased in Feb. 20
Hi, I Purchased In Feb. 20
Hi,
I purchased in Feb. 2019 a new JD robot, just used a few times
Yesterday, I was doing the servos profile, the robot twisted up and said low battery (it was charged first) then a burning electrical smell, I shut it off
I recharged the battery, all seem ok now -  do you know what that could have been?
Used it this morning ,robot is working fine now
update:
robot will not turn on - dead  3/6/2019
I replaced the fuse as you suggested to no avail, still dead, what do I do?
hey EZang
you mention you smelled a burning smell.is it posible for you to make a video?and post it here. i am very interested to know what the error might be.give your jd a second chance.
I doubled check the battery to your pictures, maybe bad
sorry for multi pics
as soon as I plug the battery in it green
you have to let the batt cool down for 30 minutes before power on the robot.also when you have used the robot,let the batt cool of for 30 minutes, before charging.great to see you tackle the problem.howlong did the charging last before the batt was fully charged.? if you can use a multi meter ,you can messure howmany volt there is in the batt.
I appreciate all that you have done, since it was new, I will just send it bask to the robot shop where I purchased it
thanks again
beware you might not get a warenty from the shop where you bouth it.may i ask what is you favorit robot?
#16
@EZang60
It looks like the Battery is good, since the charger has a green LED. That would indicate that the battery can be charged and it is has a full charge. I believe the EZ-B protection diode may have been damaged during the event that happened when JD was twisted up. It's likely that all you need is a new EZ-B.
