Openai Dall-E Image icon Openai Dall-E Image — Generate or edit images with OpenAI GPT Image from text or camera frames, with save and programmatic control commands. Try it →
High Power Servo
Hi All.
I understand that this servo does best with 6V. https://www.hobbyking.com/hobbyking/store/__8496__Turnigy_S8166M_Servo_154g_33kg_21sec.html
Can I simply connect the + and - wires from another power source to the servo, and connect the white wire to the EZ-b, or is something more complicated (like a voltage booster) needed?
thanks in advance,
Frank
you need to connect all grounds to a same point
That's slightly misleading. You need to tie all grounds together, you don't necessarily need to connect them at the same point.
What I did was cut in to the supply to the EZB, fitted a 6V regulator, made up a board for +6V and Ground. Then had the white to the EZB and the red & black to the 6V board.
Thanks.
If I connect 2 ground wires together (in a Y shape), and send one end to the servo, one end to the external 6V power supply and one end to the EZ-b, will that do the trick?
Frank
Is the External 6V power also supplying the EZB? If it is you needn't send it back there.
I think you can just link the grounds of all supplies together, so a short jumper from batter 1 ground to battery 2 ground (await confirmation, I'm not completely sure on that).
@Kudo its called common ground . if ezb and servos are powered by the same 6v source they have common ground and a separate ground wire is not needed. You would only need a ground wire if the power source feeding ezb was separate from the power source for a motor/servo which is called uncommon ground and a separate ground wire connection would be needed.;)
@Josh, can you just connect the 2 grounds of the batteries together? Really unsure on that one as I've not had to do it.
Yes you could connect the grounds together. It just cannot feed pos from ezb.... It needs to be direct to power source because ezb regulators have limitations.
My setup would be a 12V battery going to a power distribution board. 9V from that board goes to the EZ-b and 6V from that board to the servo. So indirectly, the same battery is powering both the EZ-b and servo. In this case, is one ground going to the 6V part of the power distribution board sufficient?
thanks again,
Frank
