Camera Click Servo icon Camera Click Servo — Interactive camera control for ARC: click-to-center and edge hotspots to pan/tilt servos, adjustable fine-tune and multi-camera support. Try it →
Hooking Up Electric Actuator To Servo Help???
I have a project im working on, i have electric wheel chair motors connected up through the sabertooth 2x25. im trying to add an electric actuator ( one off of electric wheel chair that tilts it back) my question is how do i connect it to a servo to make it remote operated. Thanks for your help!!
@jrick63,
Another option is the qik. It is a dual serial motor controller from Pololu. I got one from Sparkfun. Works pretty good....easy to setup too. The one i have supports two motors. Probably similar to the BV4113
Kevin
Alright guys i dont mean to waist your time, im new to this stuff and i am trying to teach myself so sorry if i seem to sound dumb. So basically for all these ideas i was given, do i still have to run a transmitter so my controller can read it and perform the task. If im going to be running my system off of two 12v batteries can i run the power to them or would i want to run a different power source to my actuators? here is a picture of what im working with!
everyone, be careful. if you are using an electric wheelchair, you may have 24 volt system. it may be 2 of the 12 volt batteries in series, which doubles the 12 volt. this will be too much voltage for the ez-b.
