Is it possible to get the sum of all the values in an array beside using a simple addition, index entry after index entry?
Thank you.
Tic Tac Toe
— Play Tic Tac Toe with your ARC robot: configurable turn, win and draw scripts, cheat commands and optional speech-recognition control.
Thank you.
Thank you! Now I'm looking forward to get the smallest value of an array... sort() doesn't seem to provide with this value while I thought it would by "magically" making the first index to bear the smallest value...
It sure does - here...
Now the $test[0] will be the value 5
Yes it does work this way indeed... I don't know what happened, for a moment it didn't or it seemed that it didn't so I constructed another one of my spaghetti codes using simple sort(value1, value2) then sort() of sort(), of sort()... lol... to eventually realize that I had done it this way already... a couple weeks ago...
Nice
Sometimes i forget to hit the REFRESH button when viewing the Variable Tab editing scripts. That's caught me a few times, maybe that's what happened
Likely cause! Totally rings a bell!
