Servo Recorder icon Servo Recorder — Record and replay named servo movements with adjustable speed/direction (-5 to +5), multiple recordings, ControlCommand triggers and status var Try it →
Is
$sonar=GetServo(d3)#sets the sonar variable to the servo position
before or after the :loop?
What happens when it hits position 180?
What's wrong with ServoUp() or ServoDown()?
Edit: Posted before previous post was seen.
The problem with that one is it'll move the servo up to position 180 then jump back to position 1. Sonar swings from side to side rather than moving from one to the other then jumping back again.
How would you go about making it move in increments from 1 to 180 then 180 back down to 1? Hint: I just posted a similar script
You may also want to add some small sleeps in there since EZ-Script can carry out thousands of commands per second.
Personally speaking, and this is what I did in PingRoam, increments of 1 may be too small. With PingRoam I had 3 positions which worked well, it could have been smoother with smaller increments than 25 steps per movement but I wouldn't go as low as 1.
Just a sample for Nomad so he can understand the basics. I learn better from example.
technopro
visuel is best to learn.for me.so i can change the values here.see pic
this is what i use sofar.
thank you very much
Nomad, you will need to know what the commands do too. Using code from other people will only get you so far.
If you want to learn from code which works I would advise reading through this topic.
In fact, read through any of my topics where I've posted scripts, I always explain each step and comment the code fully so that it's easy to follow, easy to understand and easy to change. Click here for the list of my topics.
rich i have to start somewhere.
thanks
#15
Open, Examples, EZ-Script Examples is also a good place to start. Open, Examples, EZ-Script Functions Syntax is another good place to try.
All commands are covered by at least one Example Project in the EZ-Script Functions Syntax folder in ARC. The EZ-Script Examples folder has some good examples in too from a Security Guard to controlling a 7 segment display and many more.
But it all means nothing if you don't learn what the commands do and how they work.
Check out an example. Read the script. Look up the commands used in the EZ-Script Manual. Once you get some understanding of that example move on to another one.
