Inverse Kinematic Arm icon Inverse Kinematic Arm — Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location. Try it →
How Does Sound Movement Work
I tried to find a tutorial on it, but I couldn't. Maybe it is so simple it needs no explaination.
I am thinking that I would like for the robot to turn his head and face the direction of the sound and also his body to do the same.
Is this the command that I would use to do this, and how?
OK, I found it in the EZ-B Manual. But, I need more info on HOW to do this. Do you have a tutorial on how to do this. I just want the body and head to face the sound. It cannot be my main Movement Panel because I am using the roomba panel for movement and navigation. Are there any Example Scripts on this?
Thanks,
Will this be able to work with an H-Bridge also?
