in Dj's video he had the ez-b controller on the rover with sensor. how does the ez-b interact with the rover?
— Edited
Miscellaneous Utility Plugin
— ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions.
YES in the tutorial says that,EZB you add for sensors and servo's to your design
@TECHNOPRO first connect to ROVER in wifi and make shore the wifi shows its connected then open ARC and add brookstone rover movent panel and connect to it
IF dosent connect WIFI might be your problem,like check firewall port is open or WIFI address of the brookstone rover
brookstone rover tutorial
ok so the ez-b doesnt connect directly to the rover but acts like part of it in ARC? (sorry if this is frustrating)
yes,it uses ARC if you study the video ,DJ hows how to connect it,then near the end he shows how to add like radar to it,can add any sensor or servo that EZB supports
it is a good platforrm for robots the ROVER BUT do need a working ROVER , Technopro do you have a good working brookstone rover and WIFI on your computer ,thats all you need. THEN you can add the EZB for sensors and servos for your WALL-E project,and using the sripts to control it.
I told the guy that makes the BROOKSTONE rover and he loves my project and others using it too.
