Avatar JD icon Avatar JD — 3D Avatar JD simulator with bidirectional servo sync, action sequencing, $SIM_ scripting, EZ-B emulator support and pose/movement visualization Try it →
you will need to setup a bigger private network
https://en.wikipedia.org/wiki/Private_network
Some examples:
192.168.0.0/255.255.0.0 = (65536 - 2) hosts
or if you want to go BIG!
10.0.0.0/255.0.0.0 = (16,777,216 - 2) hosts
but other issues will surface, router support, wifi congestion...
if someone creates a project like that deserves a prize no ?
Hong Kong
Hi @Alan @thetechguru (Sorry for not knwoing your username. It's kind of confusing):P
Why only one can have the movement panel?
I was wondering why is the number 249 or 256? Are these numbers the restrictions set by the ARC?
Also @ptp I think what you said was just for the case that everything is under one private network.
What if all the ezbs are in client mode with different network? Say I have one ARC installed in one PC, and I want it to remotely connect with ezbs from outside.
Thus, I believe the restrictions are only from the ARC itself, the system where the ARC is running, and the bandwidth of it.
Right?;)
@Robocen,
You can have:
  1. Multiple ARC's instances running on the same machine.
  2. 260 x EZB controllers per ARC's project
  3. Each EZB controller (Client Mode) on a different network, as long as both ends ARC and the EZB are able to communicate.
