Synbot Plugin icon Synbot Plugin — Synbot plugin for ARC: local Bot Server chatbot integration with SIML dialogs, ControlCommand API, multi-language, learning and emotion support. Try it →
How Many Lines Can Be Added To An EZ-Script
i have a design that works perfect but uses arduino board (i know you care for it ) but here is the problem been looking to slove for a long time its a SPECTROMETER i guess you know what it is now it uses 7 leds of differnet color of the spectrum including IR AND UV and photo dide to ADC input that look easy now hard part the code from arduino BOARD TO YOURS very long code because each led has a value plus a code to go with it times 7 for each sample of liquid,plus other codes then start up code and automatic code righter when you push a button for sample under test it rights the code and serial code to lcd
can it be done with your great board and have any ideas,great sensor for robotics on liquids,i want it mostly to tell different bar drinks apart and BEER
I really enjoyed this thread. I'm sure many people have learned something from it.
 read
;) code
Yes DJ did a very very good job on the code like always looking soon to post the very easy circuit,made some changes in the design ,like making the leds put out more output added more color spectrum,i added IR AND UV to get better accuracy and range plus got in SMT leds and photodiode to make it much much smaller.
But it will take some time,i have my omnibot 2000 to finish first,but my gecko cage project might need faster,since FEB 14 HAVING THEM MATED and few months latter baboies ,yes yes yes,ggoing to be another daddy soon,since they need help to hatch,feb 14 a very big day for me and my girlfriend since she holding the lady netri and i have jake
DJ what do you meen by EQUAL sign with the IF I dont know what each one meens or how to use it,have any info on it
