Dose any one know how many servos the control board will run ?
DavidWells1970
— Edited
Ultrasonic Collision Detection
— Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling.
20
Will i be ok on the heat sink or do I need to put a fan on it to keep the heat down whats your opinion
If you are going to use a lot of servos o high torque servos it will be nice if you put a fan: https://www.youtube.com/watch?v=JeqzGDOfOZo
Or connect the ground and power directly to the power source
Keep in mind that ARC will support up to 5 EZ-B connections. That means 100 servos in total.
