can i adjust the screen in ARC or is this normal.
— Edited
3 Participants
Programming With Pictures
— Use camera-detected printed cue cards (direction, pause, start) to record and run stored movement sequences for ARC robots.
Hi @Nomad
Under the controls tab at the top of ARC you can click the smart arrange button two times to get all the controls to pop to the top of the window.
Click on Smart Arrange to have ARC put all controls closer to each other.
For more screen real estate consider increasing your screen resolution or taking advantage of desktops 2 and 3 for some controls.
Both are in the menu ribbon, I am on an XP PC at the moment so can't give screenshots but you should see them if you cycle through the tabs on the ribbon along the top.
thank you jeremie double click worked.
also thank you rich for answering.
That's what I do... Desktop 1 quickly gets cluttered so I use desktop screen 2 and sometimes 3 a lot...
