Ez Line Chart icon Ez Line Chart — 4-series historical line chart to log and compare robot sensor values over time with customizable titles, colors, time axis and EZ-Script control Try it →
How To Connect Ezb To A Create 2
I have been looking on the forum for a wiring tutorial for the ezb and create 2. There are a lot of ideas and very complicated ideas that seem to work but no simple tutorial to connect ezb to a create 2.
Please let me know if there is a tutorial or can you provide me with one.
Thanks,
#89
Thanks Frank. That seems to reset for now.
#90
Jack, Can you confirm my power off in dock fix for waking a sleeping docked Roomba?
Thanks, Frank
#91
Hi Frank,
Unfortunately not at this time. The Roomba I am using would not dock so I retired and I use as a test bed at this time.
I have other Roombas but haven't had the chance to play with. I did do the manual reset and that works good.
This Roomba I cannot figure out what is wrong other than the board is going bad. I traced everything back to the board and will not dock or even charge when placed on docking station. I have 4 Roombas and it will not dock on any. I have to plug in manually so limits what I can do for now.
But it is a good test platform and everything else works on it.
Jack
#92
Jack, I know what you are going through with used Roombas
I finally decided to buy a Create 2 so that I have a known tested standard to work with
@ellis & @nink & @robohappy can you test my manualy cutting power to the dock solution to wake a sleeping docked Roomba via BRC pulse?
Thanks Frank
Twitter
#94
Thanks Frank. Good option. I appologise for not testing your solution to the need to push the clean button to activate. It is the first time it has been warm in Toronto for a long time so I am getting a vitamin D fix. I will check workaround as soon as bad weather permitting.
#95
Hi Nink, Enjoy those rays... I'm not on any schedule... I'm retired..
Thanks, Frank
#96
@faengelm,
I'm not sure if this is what you are refering to but I had the usual issue of needing to wake the Create 2 up from a sleep and the only reliable solution I came up with is to carefully remove the top pieces and get access to the clean button. I neatly soldered two fairly thin guage wires to the switch and neatly ran them up to a relay module that activates with 3.3 volts and I control it with a digital output on the EZB Controller. Then control the relay with a simple script.
Turn relay control on Wait 1 second (for example) Turn relay control off
This works really well. Just make sure the relay module you use has a control current that doesn't exceed the ezb controller digital output source current. The relay modules I use have a buffer transistor between ezb controller digital output and the relay coil input so requires very little source current from ezb controller digital ouput pin. Hope this helps....Rick
