Vertical Servo icon Vertical Servo — Drag vertically to control a servo within set min/max limits; center, release, invert, and mirror to other servos. For 3-wire GVS servos. Try it →
How To Connect To Client Mode ?
I can not connect to client mode. I have connected to ap mode, rebooted and all is ok. I then go back to set the ezb to client mode and it comes back and says it could not connect. I have entered the ssid and security key being carefull of the caps and spelling. The firewall was shut down and I have researched all the community videos. If I click on the connector button after the connection failure I recieve the menu for my router. I have gone into that menu, but could not find any relative setting to change. After a couple of days going over the connection guide I trying to find out what I'm possibly doing wrong. There are no error codes or readout after I try to connect to client mode. It is almost as if the ezb can not find my router?
Do you have anti virus software running? Avast is a known to cause connection issues... Try disabling any anti virus software, reboot and try again...
Client mode doesn't use the computer so virus scanner doesn't affect this question.
The EZ-B cannot connect to the network because
  1. The ssid and/or password is incorrect (even though you state it has been double checked)
  2. The router is AC only and not compatible with the EZ-B. The EZ-B is n/g/b
Also, you have the EZ-B COMM 1 old version. I would recommend upgrading to the EZ-B v4/2 Comm Upgrade, which has superior networking options and reliability
Lastly, if you're still struggling, then simply add a second USB WiFi interface to your PC, which is what i and many others prefer. Here's a tutorial: https://synthiam.com/Tutorials/Lesson/80?courseId=5
Oh, also verify that your router is not using WEP security. It must be using WPA2, or at least WPA. I wouldn't recommend anything other than WPA2 because everything else can be hijacked easily.
DJ
Thanks for the reply. I will try to resolve the problem by adding a usb wifi. If that doesn't work I'll upgrade. We can close the help for now. It will take me a couple of days to get the wifi because I have other items I have to take care of right know.
Again I thank you for your help.
