Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
How To Connect Your Ez-b V4 To Your Computer(both Ways[ap And Client])
How To Connect Your Ez-B V4 To Your Computer(Both Ways[Ap And Client])
I made a few How-to videos showing people how to connect the ez-b v4 in both Ap mode, and in client mode. This first video shows how to connect for the first time in AP Mode.
AP mode: The ez-b gives of its own Wi-Fi connection(hotspot) and is connected to the computer directly.
AP Mode is the mode the ez-b first starts on. You have to connect to it in AP mode before you can switch to Client Mode.
AP Mode:
Client Mode: The ez-b connects to a Wi-Fi network(router) and is connected to through the network.
Client Mode has to be set to use. You do this through the ez-b's Wi-Fi configuration page.
Client Mode:
Hope this helps anyone who needed it!
#33
Let's solve one issue at a time.
  1. I would take it out of the shell and adjust the springs that connect to the speaker to make sure they haven't just lost connection. One of my EZ-Bs needed that adjustment.
  2. Once sound is working, reset the EZ-B again back to AP mode. Connect your PC and connect to the EZ-B's web page, and run the diagnostic tests from there (making sounds, setting servos to 90).
  3. If those work, go back into ARC and make sure you are trying to connect to the default IP address of 192.168.1.1:23
Report back here successes or failures at each step. Once we know it will work again in AP mode, I'll help you get it working in Client mode. If it won't work in AP mode, or you can't get the sound back, it might be broken and further troubleshooting of client mode would be pointless.
Brazil
#34
Ok... Time for Panic! Did what you told me. No sound. No sound at all... I also tried soldering two wires to the "speaker" points in the board and connected it to a small speaker.. No sound! Used the pre amp out too.. And, sadly, no sound.
Well.. My other ezb is working ok. I solved the puzzle of the IP address... ( found the address inside the router summary)...
So.. Do you think there is anithing else to try?
#35
It sounds like it is probably broken to me. You can try separating and reconnecting the two halves of thr board to make sure all the connections are good, but beyond that I am out of ideas.
Brazil
#36
I'll try that... I'm loosing my hopes on this one...
