Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Resolved Resolved by Jeremie!
How To Control 4 Robots To Dance In Synchronization?
I am trying to get two robots to dance in synchronization I followed instructions from tutorial "how to control more than one robot" trying with two to start with However the first one is acting whereas the second one does not respond at all although it is connected to the same hot spot Please help by sending appropriate tutorials ?
Hello @Prof. John
If you were following the .PDF from this tutorial it seems it has been cut a bit short. Please continue with the next steps with the online tutorial.
You will have to import AutoPosition controls for each robot and you will have to connect each one not only to the router but also in ARC as well.
THANK YOU JEREMIE, Your suggestions very helpful
