Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
How To Cut Plastic Without Melting It
here is a idea kinda close to what they use at factory ,like where i work and desgign using platics,sensor and more for in-house tester what i made i took a old wet saw and replace the blade with a stainless steel fine tooth blade and made shore plenty of water is inside the machine,can also make your own too go very slow cut stop and go again,cuts a very smooth cut hard to do with a dremel,but can be done using like a water spray on blade and long extension cable that comes with most dremel kits
Interesting... have a pic?
i have it work,but i have another wet saw looking to change it over to have at home for my projects
easy way to make one is get a plastic box with a plate with a slot for blade and place a saw blade half way in the water
will see about getting a photo up the designs
