Prevent PC Sleep icon Prevent PC Sleep — Prevents a PC from entering sleep mode via a tiny, resizable control-keeps the system awake while minimizing UI real estate Try it →
How To Cut The Port Power After Completed The Action
Hi,
I have a problem about the servo, it is easy to burn out after completed the command. It is because the last position keep holding. Then, the servo overheat and out of service.
So, anyone can tech me that how to write the script to cut the port power until the next command order? Or Just use the "servo release" to fix it? Or other methods can improve that?
Thanks for your attention! Ricky Ma;)
Yes. The -1 means "skip this servo for this frame". And a 0 means "release the servo during this frame". Here's the documentation for the Auto Position, which can also be accessed by pressing the ? question mark: https://synthiam.com/Tutorials/Help.aspx?id=180
Quote:
  • In a frame, the position of a servo is between 1 and 180 degrees.
  • If the value of 0 (zero) is specified in a frame, this releases the servo from holding a position. The value of 0 tells the servo to stop holding a position and will become limp. You will notice the value of zero being specified on some robots where a servo is not needed within a frame, or when using Continuous Rotation Servos. Setting the value of a 0 (release) on a Continuous Rotation servo will cause the servo to stop rotating.
  • The servo value of -1 skips the servo for the frame. If a value of -1 is specified for a servo in a frame, the position of that servo is maintained and nothing is changed.
Hi DJ,
Sorry that I leave my message over here because I don't know where I can discuss with you:)
I want to learn more your AI product and programme to improve my Robot! May I have an opportunity to visit you at your Calgary office between 21st July to 26th July, 2017?
Looking forward to hearing from you soon.
Hey Ricky, i removed your email address so it is not public. As i suspect you're not going to want spam:D
Can you send a message using Contact Us form? I'll let Andres know to expect your message and he will collect your itinerary details
Hi DJ,
I got the reply from Andres this morning! But I think he misunderstood my message that is not clear.
Below link is his replied email for your reference:
I'm not easy to have this chance to Calgary from Hong Kong! So, I hope to have opportunity to meet you DJ! Would you please ask Andres to arrange?
  1. Regards Ricky Ma :)
#15
Hey Ricky - look what we got! Great book you've written. Surprising to see how much effort went into making the robot. Thank you for documenting the process and mentioning our platform:D
Ricky Mah, That's an over the top female robot you made. I've watched a number of your news coverage videos and am very impressed. Good for you to get such attention. You certainly deserve it. Nice work! Shen really looks and acts like she's a real woman.
