You may remember me from the portal robot, i am doing that but with the space core from portal 2, i have the sound pack but how would i get it to use it.
gmachine97
— Edited
Neopixel Ring
— ARC UI for onboard computers to control NeoPixel rings via serial: test/run patterns, preview and copy Arduino serial commands, includes sample code.
Assuming your audio files are MP3 or WAV...
You can either use the Soundboard: https://synthiam.com/Tutorials/Help.aspx?id=44
Or an MP3 Trigger: https://synthiam.com/Tutorials/Hardware.aspx?id=18
A very basic example is to look under File -> Examples and select the R2D2 Robot Project. There is a soundboard and a random script to demonstrate how to play sounds.
The files are wav, is it possible to make a soundboard instead getting the mp3 trigger?
Okay I understand the soundboard one know. Is it possible to make it say other things instead of the files I have like mimicking its voice?
MP3 Trigger only players the sounds loaded to the SD card so any mp3. Reformat your wav files to mp3 not hard to accomplish.
Ok but can I mimic it voice to say other things.
