Hello, I would like to gradually increase and lower the value of PWM. Does anyone know how to do? thank you
reaktor
France
— Edited
Midi Control
— MIDI I/O for ARC: send/receive notes, run per-note scripts, control PC or external instruments, with panic to stop stuck notes.
You could script it quite easily.
Apologies if the code is a bit messy and not explained too well I'm strapped for time but it should give an idea (hopefully)
Ok, I understand how the code works. Now it's clear. Thanks
Or you can servospeed() command. It applies to PWM as well
for example
Even I learn something new from time to time, I did not know ServoSpeed() applied to PWM too, that's much easier
