User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
How To Hook The Gripper To Six Hexapod ?
Hello people !
I want to add extra abilities to my six hexapod but i dont know to which ports i can connect the manipulator gripper I was tried connect the gripper in those ports that were connected to Jd humanoid , but the gripper dont work :( How to hook the gripper to six hexapod ?
      the gripper:
you can choose any left over ports.here an excample,i choose d23/d22/d21
1=connect your six
2=go to the webpage and set ports at 90 degrees
3=calibrate you servo's and save
4= go to Auto Position and ad ports as seen in the pic.
do you have a pic when the extra servo are connected to six ? and what do you want your six to do?
I’ll make you a quick video for next week, if you haven’t figure it out.
thanks, i was able to install the gripper
That's great! Thanks for letting me know - I was waiting to hear back from if you required a video instruction. Sounds like you figured it out:D:D
