Microphone icon Microphone — Record audio from your PC mic, auto-trigger and edit sample rate/effects, then play or export recordings to an EZ-B v4 SoundBoard for robot playback. Try it →
How To Limit Range Of A Motor
Afternoon All
So I'm using an H-Bridge and panel to turn the head section of my robot. It works great but I want to limit the range of the revolution. For example I'd like to have the section only be able to move from 2:00 position to the 10:00 position and no more. I've experimented with various controls haven't had any luck.
Anyone care to chime in?
Thanks,
Daniel
You could use micro switches at each of the max travel and hook them to digital inputs. Or a few guys here have used pots and hooked them to acd I believe. Then set up your limits as variables.
