Maestro Servo Controller icon Maestro Servo Controller — USB control for Pololu Maestro (6/12/18/24) via ARC Vx ports. Maps Vx to Maestro channels; supports position, speed, acceleration, release. Try it →
yes, iam having a pc - windows 7 , did the robot work after disconneting the wifi with pc. and can i control pneumatic cylinder with ez-b v4
The robot controller (EZB(4) controls the robot. It sends and receives all the electrical signals between the robot and the controller. What is done with the signals received and sent from and to the robot and its hardware that are wired to the controller (EZB(4)are all stored in the PC. There is no room for all the functions that can be performed by your robot to be stored onboard the EZB(4) controller. The PC and ARC store your instructions that you build to control your robot and send them to the EZB(4) controller using WiFi.
If you want your robot to be self contained then as suggested in other posts, get a small computer that will support Windows and ARC and install it inside your robot.
did the robot control after disconnecting wifi with pc
If you mean your home/school wifi then yes, it will, but you have to connect to the ez-b at all times for it to work.
can i connect solenoid valve to robot
#15
@ramcharan ...With a relay probably or some kind of Mosfet
#16
I have a video that can help you.:) this is the name on YouTube. But it's only one of the things you can do. I'll send you another video too. Click To Watch Video;)
