XV Lidar Bridge icon XV Lidar Bridge — Neato XV LIDAR integration for ARC with live radar, 8-zone obstacle detection, NMS support, calibration, and scan watchdog monitoring Try it →
How To Pwer A Ez Camera From A Power Source
all you need is usb type a female breakout board and a 5 volt source,plus usb charging cable that comes with the camera here is a link to usb breakuot board for $6.95 ic shipping
usb breakout board
first link is usb 3.0
usb 2.0 breakout board
this is the one i bought ,other dont know if will work on usb 2.0 type A USB MALE and its little cheaper at $6.58
Brilliant, i was wondering what the digital port he uses int he video is for.
if you dont want to open the camera you use the boards or cut the cable to charge the battery
if you want to try to open the camera and remove the battery you dont need the board or cable
im so sorry, im still a little lost....
my goal here is to remove the camera from case...cut the USB cord and a servo extension cord and solder them just like in sures video(power, ground and white cable for signal)
i was hoping this would power/charge the battery so i dont have to charge the camera on its own... or would this still require me to charge the camera battery on its own?
if i use the boards in the opening post will this require the removal of the battery? or not?
is the purpose of the boards in the opening post to keep the battery and recharge it?
man im lost...
there is no usb cable you need to cut,if you remove the case there is only the battery you need to remove and attach to wires to go to your board,can use battery for another project or toss it there is no signal wire that is for the servo
the camera is wireless it use bluetooth
try to understand the begining of the post its only for if you DONT WANT TO OPEN the camera case ONLY
ok gotcha,since i do want to open the camera this does not apply to me.
but.....the usb cable i meant is the power cable that comes with the camera...Sures cuts off the usb part of it and uses the red and black cables to connect to a servo extension cables....then the white cable from the servo cable he uses to solder on to the camera it self....
then plugs the end of that extension cable to the ezb.....
does this charge the battery?
#15
hahahahaha ok cool, so i will follow the video to the t, and i will be good to go.....
Dude thanks for your time...i really appreciate it.
you made a dumbass in california very happy about his purchases.
#16
one reason i dont like to cut the usb cable,most have very thin wires and they break very easy so thats why made it easy just to use a breakout board no cable to cut
