Sherpa-ONNX Speech To Text icon Sherpa-ONNX Speech To Text — Offline continuous speech recognition with wake word support, custom phrases, and real-time transcription using sherpa-onnx models on ARC Windows. Try it →
Resolved Resolved by ptp!
How To Recoed Video In C#
Hi especially @ptp
Do u remember the previous camera project ? I've add two new buttons one for start recording video & the other is for saving video ,I've try the following code but it doesn't work
Code:
EZ_B.EZ­Bv4­Video.­Start(EZ_B.EZB, ­System.­String, ­System.­Int32) //and camera.AVIStartRecording("vedio1",30);
You have to use the Camera module, not the raw ezbv4video module. The camera module has the recording built in, unless it's something you need full control over.
I will provide an example of both when I am in front of the computer in a few hours.
the camera.AVIStartRecording should work.
an example:
        private void StartOrStopVideoRecordingButton_Click(object sender, EventArgs e)
            if (!this.camera.IsActive)
                this.WriteDebug("ERROR: Camera not started");
                return;
            //Note: .Tag = "Start Video Recording|Stop Video Recording
            var labels = this.StartOrStopVideoRecordingButton.Tag.ToString().Split(new[] { '|' });
            if (!this.camera.AVIIsRecording)
                var filename = this.ImageFileNameTB.Text + ".avi";
                this.WriteDebug("AVI Start recording to file=" + filename+ " ." );
                const int framesPerSecond = 3;
                this.camera.AVIStartRecording(filename, Camera.VideoCodec.MPEG4, framesPerSecond);
                this.StartOrStopVideoRecordingButton.Text = labels[1];
            else
                this.WriteDebug("AVI Stop recording" );
                this.camera.AVIStopRecording();
                this.StartOrStopVideoRecordingButton.Text = labels[0];
It's simple and straight forward.
I've updated the Github repository. if you still have issues, you can check the example.
@DJ would u difference between them more clearly
@ptp there is no words enough to thank u
@DJ thanks for ur recommendation
