Dialogflow icon Dialogflow — Add Google DialogFlow NLP to ARC: conversational intents, parameter prompts, scripted responses, service-account setup and programmatic robot control. Try it →
How To Update Installed Plugin
OK, I give up. How do I update an already installed plugin in ARC? I asked once before and was told ARC automatically asks if I want to update the plugin when it opens. I've never been asked and I have the Bing Voice Recognition plugin installed. I know from another post that this plugin has been recently updated.
In my ARC Options, my box is Unchecked for "Do not check for ARC and plugin updates". confused
Quote:
How may I ask did you find out how to update plugins?
I usually open ARC first, then select my project. Doing that, I am prompted to update.
I think the majority of users open that way. Since you are mostly working with a single, highly customized robot, it makes sense for you to open via a custom shortcut or just opening the project, and I think not being prompted for updates would be the preferred method in that environment.
I am all for more choice, so if DJ could make it an option to automatically check or not check, I would be happy, but I also think he has more important stuff on the todo list.
I do it the same way @Alan does... I have many ARC projects for this that and the other thing... I open ARC first and then open or create a new project from there...
Thanks guys. I understand. I really hadn't considered having many robots using different projects being controlled from the same computer at different times. ;)
