I'm really having trouble using the joystick control. How do I connect the controller and how do I use the control? confused
Zeeko2600
— Edited
EZMQTT Client
— MQTT client for ARC: connect to brokers, publish/subscribe topics, map incoming messages to variables (incl. binary arrays) and run scripts.
zeeko avery page has a question mark.if you click on that you get explanation, some video to.
First off, make sure you have the drivers installed in your PC for your joystick. Below is taken from the learn section that tells you how to connect a joystick to ARC...
Once you hit the refresh button and chosen your joystick, it should connect. Then you can choose a "Movement Panel" from the top bar menu and your joystick will automatically control the Movement Panel which controls your robot. You can also use scripts with the joystick control as well.
Below is the link for the whole article for connecting the joystick and a quick video demo.
Joystick tutorial
Thank you so much! I can now use the joystick control.
No worries. Glad I could help.
