Dual-Axis Compass icon Dual-Axis Compass — Dual-axis I2C magnetic sensor for EZ-B robots enabling magnetic direction sensing; requires short 2-3 in wiring. Third-party hardware. Try it →
How can I install a Python library in ARC?
How Can I Install A Python Library In ARC?
Hi Athena,
I added a "Script" to my ARC project and selected Python as the scripting language. When I tried to use the import asyncio statement, I encountered an error stating "No module named 'queue'." It seems I need to install a library within the scripting environment so that the 'queue' module is recognized. Could you guide me on how to achieve this?
Thanks,
Satish
EZ-Inmoov Robot Head by EZ-Robot & Gael Langevin
EZ-InMoov Robot Head with Synthiam ARCx: face tracking, speech recognition, Talk Servo jaw motion and AI conversation
Servos 8
ADC 2
Digital 8
Hello Satish,
To install a Python library in ARC, you can follow the steps outlined in the Synthiam documentation. Here's a brief overview of how you can add custom Python modules to your ARC project:
  1. Access the Python Environment:
    • ARC uses an embedded Python environment, which means you can add custom Python modules to it.
  2. Install the Required Module:
    • You can install Python modules using the pip command. However, since ARC's Python environment is embedded, you need to ensure that the module is compatible with the version of Python used by ARC.
  3. Use the Module in ARC:
    • Once the module is installed, you can use it in your Python scripts within ARC by using the import statement as you would in any standard Python environment.
For detailed instructions, please refer to the Synthiam documentation on adding custom Python modules.
If you encounter any issues or need further assistance, feel free to ask!
Best regards, Athena
#3   — Edited
Hi Synthiam Support,
Actually, thinking about it again, 'asyncio' is a module that is already built into Python. I am able to import it from outside of ARC without any errors. From inside ARC, I get the error "No module named 'queue'" What do you think I am missing?
Thanks, Satish
@Athena @Synthiam Support
Interesting - when i
import asyncio
I receive
Start
Done (00:00:01.0794938)
So it looks like queue is missing, but Queue (uppercase Q) is there. Python changes their naming conventions all the time throughout versions. I wonder if there's some library suck in limbo.
Can anyone else please check if you are able to import this library in your instance of ARC?
#6   — Edited
There doesn’t seem to be a reason to import it because asyncio exists. What doesn’t seem to exist is the dependency called queue. But the internet said it should be Queue with a capital q. Have any google searches about what Queue or queue or what ever is going on?
I can’t seem to find a definite answer on what libraries queue or Queue or Queues for asyncio.
since the error is about missing queue, maybe use the instructions to add queue library using pip?
@Synthiam Support
I could not figure this out yet. Would you be able to help? I have a deadline coming up and this is critical. Do you offer paid zoom/phone consultations? If yes, we could do that as well. Let me know.
@athena I am trying to learn how to install python libraries so they can be accessed from within the ARC software. I have followed the instructions: Created a PIP.INI file and included the location of the ARC python modules [global] target=C:\Users[..my directory..]\Documents\ARC\Python Modules
I ran the example install: pip install numpy
It seemed to work and created a number of files in the above directory.
But when I try and import numpy in a Python script it says: invalid syntax
This is the script: import sys print(sys.executable) import platform print(platform.python_version()) import numpy
This is the output in the console: Start
None 3.4.1 invalid syntax Done (00:00:00.5168603)
