NMS Example icon NMS Example — Example NMS Level #1 navigation skill showing subscription to combined scan+location data, displaying position and scan info; source code included. Try it →
Resolved Resolved by Athena!
How Can I Use Python Script To Return Values From A Mic Array?
How can I use a Python script to return values from a respeaker mic array connected to my windows SCB that is running ARC?
I have python scripts that can return sound direction that I would like to use to trigger movements.
I have the latest Python installed on the window 11 pro PC that also runs the ARC application. Is there anything else I need to do configuration wise for ARC to support Python?
USB
Servos 12
ADC 6
Digital 14
Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations.
Script Monitor by Synthiam
Monitor and diagnose running ARC scripts: view active script labels, statuses, and stop long-running or background scripts easily.
Real-time microphone VAD using FFT to detect speech start/end and trigger scripts, with live level graph and sensitivity tuning
To integrate Python scripts that return values from a ReSpeaker mic array into your ARC project, you'll need to follow a few steps to ensure ARC can execute Python scripts and communicate with the Python environment on your Windows 11 Pro PC. Here's a step-by-step guide:
  1. Ensure Python is Correctly Installed:
    • Verify that Python is installed on your system and that it's added to the system's PATH. You can do this by opening a command prompt and typing python --version. If Python is correctly installed, you should see the version number displayed.
  2. Install Necessary Python Packages:
    • If your Python scripts depend on specific libraries (e.g., for processing audio input from the ReSpeaker mic array), ensure these are installed in your Python environment. You can install packages using pip, e.g., pip install sounddevice numpy.
  3. Configure ARC to Use Python:
    • ARC supports executing Python scripts directly. However, ensure ARC is configured to use the correct Python interpreter. This is typically handled automatically, but you can specify the Python executable path in your system's environment variables if needed.
  4. Create a Python Script in ARC:
    • In ARC, you can add a Python Script skill to your project by going to Project -> Add Skill -> Scripting -> Python Script.
    • Within this skill, you can write or paste your Python code that interacts with the ReSpeaker mic array. If your script is designed to return sound direction, you can use this data within ARC to trigger other actions or movements.
  5. Communicate Between Python and ARC:
    • To use the sound direction data from your Python script to trigger movements in ARC, you can utilize ARC's global variables. Use the setVar() function in Python to set a global variable with the sound direction data. For example:
      setVar("$SoundDirection", direction)
    • Other skills in ARC can then read this global variable and react accordingly. For instance, you can use an EZ-Script or another Python script within ARC to read the $SoundDirection variable and control servos or motors based on the sound direction.
  6. Running Your Python Script:
    • Once your Python script is set up in the Python Script skill, you can run it directly within ARC. Ensure your ReSpeaker mic array is correctly connected and recognized by your PC.
  7. Debugging and Monitoring:
    • Use the Script Monitor skill you've added to your project to monitor the execution of your Python scripts. This can help in debugging if the scripts are not behaving as expected.
    • The Voice Activity Detection skill can complement your setup by providing events when voice activity is detected or not, which can also trigger scripts or actions within ARC.
By following these steps, you should be able to integrate your Python scripts for processing input from the ReSpeaker mic array into your ARC project, enabling you to create interactive and responsive robot behaviors based on sound direction.
You're welcome! If you have any more questions or need further assistance with your project, feel free to ask. Happy building!
