Miscellaneous Utility Plugin icon Miscellaneous Utility Plugin — ARC utilities: DataQuery for SQL/ODBC/OLEDB/Excel with parameterized queries returning array variables; Ticks/Millis timing functions. Try it →
How Do I Assign A List Of Values To An Array Using Script Language
How do I assign a list of values to an array using the script language in Synthiam ARC? For example, I want to create an array like this: $MyArray = ["value1", "value2", "value3"].
Manage and execute multiple scripts in a single Script Manager using ControlCommand(), with Control Details showing available commands.
Adds GetLineContainingFromArray() ez-script function to return the first array item that contains specified text, simplifying substring searches.
To assign a list of values to an array using the script language in Synthiam ARC, you can use the defineArray() function. Below are the steps and an example of how to do this in JavaScript or Python, which are the preferred scripting languages in ARC.
Steps:
  1. Add the Script Skill: Ensure you have the Script Collection skill added to your project.
  2. Open the Script Editor: Open the script editor for the Script Collection skill.
  3. Define the Array: Use the defineArray() function to create and assign values to the array.
Example in JavaScript:
// Define an array with specific values
var myArray = ["value1", "value2", "value3"];
// Print the array to verify
print(myArray);
Example in Python:
# Define an array with specific values
# Print the array to verify
print(myArray)
Using defineArray() in EZ-Script:
If you prefer to use EZ-Script, you can use the defineArray() function as follows:
defineArray($MyArray, 3, "value1", "value2", "value3")
print($MyArray)
Using the Get Line Containing From Array Skill:
If you want to use the Get Line Containing From Array skill, you can follow these steps:
  1. Add the Get Line Containing From Array Skill: Ensure this skill is added to your project.
  2. Use the Skill in a Script: Use the skill within a script to manipulate arrays.
Example Using Get Line Containing From Array in EZ-Script:
# Use the Get Line Containing From Array function
$line = GetLineContainingFromArray($MyArray, "value2")
# Print the result
print($line)
Resources:
Feel free to ask if you have any more questions or need further assistance!
Steps:
// Define an array with values
print(myArray);
Example in Python:
# Define an array with values
print(myArray)
print($MyArray)
# Print the result
print($line)
Resources:
