Pandorabot AIML2 icon Pandorabot AIML2 — Connect ARC to Pandorabots AIML2 to run AI-driven virtual personalities for human-like text or voice chat, using API keys and script hooks. Try it →
#1   — Edited
Absolutely, you can create a JD style robot with wheels instead of legs. You will need to use the HBridge PWM robot skill in ARC to control the L298N motor controller. This skill will allow you to control the speed and direction of the motors connected to your L298N.
For the arms, you can use the Auto Position robot skill to control the servos. This skill allows you to create frames and actions for your robot, which can be used to move the arms in specific ways.
You can find more information on how to use these skills in the ARC software in the Learn section of the Synthiam website. Here are the links to the relevant articles:
Remember, you will need to connect your EZ-Bv4 to your computer and add these skills to your project in ARC. Once you have done that, you can configure the skills to work with your specific hardware setup.
