Servo Speed icon Servo Speed — Adjust servo/PWM speed (0-20) between two positions to quickly experiment and tune motion; select board/port; settings aren't saved. Try it →
How do I... not be hopelessly lost?
How Do I... Not Be Hopelessly Lost?
I'm sorry for ANOTHER stupid question, but I'm having a REEEALLY hard time following the Tutorials and searching for help in the forums here. I've just attached my ultrasonic distance sensor to my EZ-B4, but I can't figure out how to do anything with it. At this point, I just want to have my robot navigate autonomously (which, to the best of my knowledge, should be a fairly simply process) before moving on to more complex tasks, but I've got no idea how to proceed from here.  What do I need to do to figure this out?
Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output
Ultrasonic Radar by Synthiam
Ultrasonic on a servo sweeps 180°; radar shows distances and obstacles, integrates with movement panels for automatic avoidance, scriptable GetPing
Stops robot movement (no steering) when an EZB-connected ultrasonic sensor detects an object within a set range; integrates with scripting and paused polling.
#25
No, I can't connect to the Adventurebot, the arrow keys work fine when I'm not trying to use the ultrasonic, and the original Robie Sr. wheels that I'm using aren't an issue.
#26
And now my camera's not connecting... Wtf?...
hi bobsheaux
do you save your project on your pc?and maybe you can take a new window ultrasonic. check the cabke from your camera bolt sides.
#28
Yes, I save my project constantly.
And as near as I can tell, the connection of the cable on both ends of my camera is perfectly fine.
maybe its possible you have a bad download .you can remove it and redownload it. also i read some post about the camera cable.solution is to turn the cable 180 degree.
#30
No, it's still not connecting.
can you try another camera window?
#32
Okay, THAT worked, THANK YOU. lol
And I guess I'll poke around what the other tutorials have to say about the ultrasonic sensor.
