How do I load an audio file in blocky? All I get is a small white line when I try to load an audio file. I am using ARC-Beta-2020-03-19-00-19052
Thanks Steve
Feetech Serial Bus Servo
— Control Feetech SC serial bus smart servos via EZB UART or PC COM port with ARC virtual ports, speed, position, release, and acceleration.
Thanks Steve
ezbv4 is much easier in averything.it will work.
I want to use 2812b programable led strips, do you know how to get them working on EZBv4 and IoTiny?
no sorry i am not a programmer.i am a beginner with some little skills. someone chall chime in and help you.you can post pics and link, off the led strips you want to use . that will help others .
Hi Steve, to use neopixel style LEDs you'll need an arduino to generate the precise signals to control the LEDs, from their you can hook the arduino up to the EZ-B via uart or just program the arduino to trigger off a high or low sent to one of the inputs. There's a few threads about it in the community here, just search for "Neopixel" or "addressable LEDs" or "WS2812B".
Steve, use the soundboard (pc) to have sound play out of the latte panda’s speaker output
Arduino’s are not powerful enough to play streaming audio like the ezb can.
if you go the route of an ezb, connect it to the latte panda so you don’t require the WiFi and therefore get faster response.
Hi Jeremy Yer with the searching Ive done I figured Id have you use arduino for 2812b leds. I see there is a neoblaster control for ARC, does that work ok? Shame I cant find flexible neoblasters.
Hi DJ Ive been playing a little bit with Soundboard PC, I take it I can point to the sounds I load in soundboard pc from ezscript (or use a path/filename) line of code.
Ill have a tinker tonight after work
Use the ControlCommand() when editing script. I recommend using Javascript over EZ-Script. Because EZ-Script is terrible
Simply right click in the editor and all of the control commands will be presented. You can click here on the word ControlCommand to read what that means.
DJ, it's odd and kinda sad hearing you say EZ Script is terrible. You worked so hard on it making it so EZ for us.
