Arduinocoms icon Arduinocoms — EZB v4-Arduino I2C bridge for ARC: supports custom C# code and reads gamepad or Wii controller inputs for robot control Try it →
How To I Include Pauses In Speech Synthesis.
How can I incorporate natural pauses into a speech script using Synthiam ARC? For instance, I want it to say "HO pause HO pause HO" with noticeable pauses in between.
Currently, my Santa head is saying "HO HO HO" too quickly, and I would like to slow it down for a more natural delivery.
EZ-B Iotiny by EZ-Robot
Servos 8
ADC 2
Digital 8
Azure neural text-to-speech for ARCx scripts and skills, with multilingual voices, SSML support, and EZB audio output.
To incorporate natural pauses into your speech synthesis using the Advanced Speech Synthesis skill in Synthiam ARC, you can use the Speech Synthesis Markup Language (SSML). SSML allows you to add pauses, change pitch, speed, and more to create a more natural-sounding speech.
Here's how you can add pauses to your speech script:
  1. Open the Advanced Speech Synthesis Skill: In your ARC project, locate the Advanced Speech Synthesis skill and open its configuration.
  2. Use SSML for Pauses: You can use the <break> tag in SSML to add pauses. The time attribute specifies the duration of the pause. For example, to add a half-second pause, you can use <break time="500ms"/>.
  3. Example Script: Here's an example of how you can structure your script to include pauses:
    <speak>
      HO <break time="500ms"/> HO <break time="500ms"/> HO
    </speak>
  4. Implement the Script: Use the Audio.saySSML() function to implement the SSML script in your project. Here's how you can do it in JavaScript:
    var ssml = '<speak>HO <break time="500ms"/> HO <break time="500ms"/> HO</speak>';
    Audio.saySSML(ssml);
  5. Test the Speech: Run your script to test the speech output. Adjust the time attribute in the <break> tags as needed to achieve the desired pause duration.
By using SSML, you can fine-tune the speech output to sound more natural and fit your specific requirements. If you have any more questions or need further assistance, feel free to ask!
#2   — Edited
Are you using the advanced speech recognition robot skill that has nicer voices? or the built-in one that uses the Audio.say() command?
var str = "<speak version='1.0' xmlns='https://www.w3.org/2001/10/synthesis'; xml:lang='en-US'>" +
 "HO <break time='500ms'/>" +
 "HO" +
 "</speak>";
Audio.saySSML(str);
And of course, the laziest way is to just add periods to force a delay between the words haha.
Audio.say("ho... ho... ho...");
You can also read about how to add inflection and change the pitch and stuff for SSML: https://synthiam.com/Support/javascript-api/Audio/saySSML
Edit: PS if you want it to come out of the EZB, use the Audio.SaySSMLEZB() command instead
#3   — Edited
This is a good one. It sings... I had ChatGPT generate this for me. Thing is, I really had to tell it to exaggerate the pitch values to extreme because the original version didn't do much.
    "<prosody pitch='+80%' volume='loud'>Dashing</prosody> " +
    "<prosody pitch='+120%' volume='loud'>through the snow</prosody> " +
    "<break time='300ms'/>" +
    "<prosody pitch='+150%' volume='loud'>in a one-horse open sleigh</prosody>, " +
    "<break time='500ms'/>" +
    "<prosody pitch='+100%' volume='loud'>o'er the fields</prosody> " +
    "<prosody pitch='+140%' volume='loud'>we go</prosody>, " +
    "<prosody pitch='+180%' volume='loud'>laughing</prosody> " +
    "<prosody pitch='+200%' volume='loud'>all the way!</prosody> " +
    "<break time='700ms'/>" +
    "<prosody pitch='+120%' volume='loud'>Bells on bobtail ring</prosody>, " +
    "<prosody pitch='+160%' volume='loud'>making spirits bright</prosody>, " +
    "<prosody pitch='+140%' volume='loud'>what fun it is</prosody> " +
    "<prosody pitch='+180%' volume='loud'>to laugh and sing</prosody>, " +
    "<prosody pitch='+200%' volume='loud'>a sleighing song tonight!</prosody> " +
    "<break time='1s'/>" +
    "<prosody pitch='+150%' volume='loud'>Jingle bells,</prosody> " +
    "<prosody pitch='+200%' volume='loud'>jingle bells,</prosody> " +
    "<prosody pitch='+250%' volume='loud'>jingle all the way!</prosody> " +
    "<prosody pitch='+120%' volume='loud'>Oh what fun</prosody> " +
    "<prosody pitch='+160%' volume='loud'>it is to ride</prosody> " +
    "<prosody pitch='+200%' volume='loud'>in a one-horse</prosody> " +
    "<prosody pitch='+250%' volume='loud'>open sleigh!</prosody> " +
    "<prosody pitch='+180%' volume='loud'>Jingle bells, jingle bells,</prosody> " +
    "<prosody pitch='+160%' volume='loud'>Oh what fun it is</prosody> " +
    "<prosody pitch='+200%' volume='loud'>to ride</prosody> " +
    "<prosody pitch='+300%' volume='loud'>in a one-horse open sleigh!</prosody>" +
    "</speak>";
Audio.saySSML(str);
How did you make out with the HO HO HO robot?
