Conversational Menu icon Conversational Menu — Voice menu tree to navigate options and run scripts on ARC robots. Multi-level, customizable prompts, speech I/O, timeout and repeat/back. Try it →
How To Rem Out A Piece Of Code
Hello folks been awhile, But I have  a silly question and cant seem to find it.
Question is, when writing a script, say in Ez-script, if I want to "rem" out  a line of code but not erase it, you usually can put a # in front of the command, but in Javascript, I thought it was a ; that does the same thing. This does not seem to be true. I'm gathering there is another symbol that is used instead? thats what I am trying to find out.
thanks so much:)
Real-time EZ-Script console for ARC: enter and execute single-line commands, view output, clear display, and recall history with UP/DOWN.
#1   — Edited
In EZ-Script, you can comment out a line of code by using the "#" symbol at the beginning of the line. This will make the script ignore that line when it's running.
In JavaScript, you can comment out a line of code by using "//" at the beginning of the line. If you want to comment out multiple lines, you can use "/" at the beginning and "/" at the end of the section you want to comment out.
Oh wow, great to know, thank you. Consider this closed:)
