Auto Position (Gait) icon Auto Position (Gait) — Create servo frames and actions to animate gaits and gestures with automatic motion planning, software ramping, movement panel, import/export Try it →
India
How To Control Neopixels From Arduino Mega
How can I control NeoPixel LED strips when they are directly connected to an EZ-B or an Arduino Mega using digital pin D1? I would like to know how to configure it for my specific needs. In my setup, I plan to use 2 to 4 LED strips connected to digital pins D0 through D3. Will the NeoPixel skill in Synthiam ARC work for this configuration?
USB
Digital 21
Connecting a NeoPixel strip directly to an EZB (such as an Arduino Mega) using digital pins like D0-D3 can work, but it requires careful consideration of the timing and power requirements of the NeoPixels. NeoPixels require precise timing to control the LEDs, which can be challenging to achieve directly from a microcontroller like the Arduino without additional hardware or libraries.
Steps to Configure NeoPixels with an Arduino Mega:
  1. Library Installation:
    • First, ensure you have the Adafruit NeoPixel library installed in your Arduino IDE. This library provides the necessary functions to control NeoPixels.
  2. Wiring:
    • Connect the data input of each NeoPixel strip to the respective digital pins (D0-D3) on the Arduino Mega.
    • Ensure that all NeoPixel strips share a common ground with the Arduino.
    • Provide adequate power to the NeoPixel strips, as they can draw significant current. Use a separate power supply if necessary.
  3. Arduino Code:
    • Use the Adafruit NeoPixel library to control the LEDs. Here is a basic example to get you started:
#include <Adafruit_NeoPixel.h>
// Define the number of LEDs per strip
#define NUM_LEDS 4
// Define the pins for each strip
#define PIN_STRIP1 0
#define PIN_STRIP2 1
#define PIN_STRIP3 2
#define PIN_STRIP4 3
// Create NeoPixel objects for each strip
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(NUM_LEDS, PIN_STRIP1, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip2 = Adafruit_NeoPixel(NUM_LEDS, PIN_STRIP2, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip3 = Adafruit_NeoPixel(NUM_LEDS, PIN_STRIP3, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip4 = Adafruit_NeoPixel(NUM_LEDS, PIN_STRIP4, NEO_GRB + NEO_KHZ800);
void setup() {
  // Initialize each strip
  strip1.begin();
  strip2.begin();
  strip3.begin();
  strip4.begin();
  // Set all pixels to 'off'
  strip1.show();
  strip2.show();
  strip3.show();
  strip4.show();
void loop() {
  // Example: Set all LEDs on strip1 to red
  for (int i = 0; i < NUM_LEDS; i++) {
    strip1.setPixelColor(i, strip1.Color(255, 0, 0)); // Red
  strip1.show();
  // Add similar code for other strips as needed
  1. Considerations:
    • Ensure that the total current draw does not exceed the power supply's capacity. Each NeoPixel can draw up to 60mA at full brightness (white).
    • If you experience flickering or instability, consider using a level shifter to convert the Arduino's 5V logic level to the NeoPixel's required level.
Using Synthiam ARC:
If you want to integrate this setup with Synthiam ARC, you would typically use a custom script or robot skill to send commands to the Arduino, which then controls the NeoPixels. However, the direct control of NeoPixels from ARC without a dedicated controller like the NeoPixel Blaster may not be feasible due to the precise timing requirements.
For more advanced control and integration with ARC, consider using a dedicated NeoPixel controller or the NeoPixel Blaster design, which can handle the timing and power requirements more effectively.
If you have further questions or need more detailed guidance, feel free to ask!
