HTTP Server icon HTTP Server — Remote web control of ARC desktop: live screen interaction, movement control, camera list, EZ-Script/ControlCommand console with remote execution. Try it →
Resolved Resolved by Athena!
How To Control Tank Tracks Without Skid Turns?
How to Control Tank Tracks Without Skid Turns?
I am planning to use an Arduino Uno with EZB firmware and two H-bridge controllers, one for each of the right and left track motors, with PWM speed control.
The way I want this to work is with a single joystick control:
  • For a right turn: the left track moves forward, and the right track moves backward.
  • For a left turn: the opposite of the above.
Can this be done with one joystick, or will it require a joystick for each track?
USB
Servos 12
ADC 6
Digital 14
Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning.
XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts.
Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives
Controlling tank tracks without skid turns using a single joystick is definitely possible with the setup you have. You can achieve this by configuring the joystick to control the speed and direction of each track independently. Here's a step-by-step guide to set this up in ARC:
Step 1: Configure the Dual H-Bridge w/PWM
  1. Wiring: Ensure your Arduino Uno is connected to the Dual H-Bridge as per the wiring diagram provided in the Dual H-Bridge w/PWM manual.
  2. Add the Skill: Add the Dual H-Bridge w/PWM skill to your ARC project.
  3. Settings: Configure the ports for the left and right motors in the Dual H-Bridge w/PWM settings.
Step 2: Configure the Joystick (XInput)
  1. Add the Skill: Add the Joystick (XInput) skill to your ARC project.
  2. Device Selection: Connect your joystick to the PC and select it from the device dropdown in the Joystick (XInput) skill.
  3. Settings:
    • Go to the Left Stick Tab and enable the "Joystick #1 Controls Movement Panel" checkbox.
    • Set the Movement Control Deadband Value to a suitable value to avoid unintentional movements.
Step 3: Custom Movement Panel v2
  1. Add the Skill: Add the Custom Movement Panel v2 skill to your ARC project.
  2. Configure Scripts: You will need to write custom scripts for each movement direction. Here’s an example of how you can configure the scripts for tank track control:
Forward Movement
// Move both tracks forward
Servo.setPosition(D0, 180); // Left track forward
Servo.setPosition(D1, 180); // Right track forward
Reverse Movement
// Move both tracks backward
Servo.setPosition(D0, 0); // Left track backward
Servo.setPosition(D1, 0); // Right track backward
Left Turn
// Left track backward, right track forward
Right Turn
// Left track forward, right track backward
Step 4: Integrate Joystick with Custom Movement Panel
  1. Button Mapping: In the Joystick (XInput) settings, map the joystick movements to the custom Movement Panel scripts.
    • For example, map the forward movement of the joystick to the forward script in the Custom Movement Panel.
    • Similarly, map the other joystick movements to the respective scripts.
Step 5: Testing and Calibration
  1. Test the Setup: Connect your Arduino Uno to the PC and test the joystick controls.
  2. Calibrate: Adjust the PWM values and deadband settings as needed to ensure smooth and responsive control.
Example Code for Joystick Integration
Here’s an example of how you can map the joystick movements to the custom Movement Panel scripts:
// Map joystick movements to custom  Movement Panel scripts
map = function(value, in_min, in_max, out_min, out_max) {
    return (value - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
while (true) {
    var x = getVar("$JoystickX1");
    var y = getVar("$JoystickY1");
    if (y > 0) {
        // Forward
        ControlCommand("Custom  Movement Panel v2", "Forward");
    } else if (y < 0) {
        // Reverse
        ControlCommand("Custom  Movement Panel v2", "Reverse");
    } else if (x > 0) {
        // Right Turn
        ControlCommand("Custom  Movement Panel v2", "Right");
    } else if (x < 0) {
        // Left Turn
        ControlCommand("Custom  Movement Panel v2", "Left");
    } else {
        // Stop
        ControlCommand("Custom  Movement Panel v2", "Stop");
    sleep(100);
By following these steps, you should be able to control your tank tracks without skid turns using a single joystick. If you encounter any issues or need further assistance, feel free to ask!
Absolutely all movement panels will do that.
Thank you for the information.
