Slide Script icon Slide Script — Adjust a numeric variable via slider (0-1000) with customizable min/max, center button and scripts triggered on value change or bonus button press. Try it →
Singapore
How to modify the wall-e robot wheels
How To Modify The Wall-E Robot Wheels
Hi,
I like the video of "real wall-e" very much, and very interested in make one. I'v bought the u-command wall-e (it's pretty expensive). And have taken apart it. I found the the wall-e only have one DC Motor connected with its left wheel, and right wheel is driven by left wheel through a special group of gears, which make right wheel always turns forward, no matter left wheel turns forward or backward. By this design, wall-e can only go forward and turn left, cannot not turn right or go backwards. So I need to use another motor to control the right wheel solely. That means I have to modify the gears of right wheel. But all gears are sealed in one small plastic box and cannot be open. Anyone have suggestions ?
Best Regards, Jackie Ju
I noticed the same thing when I opened mine up. I went, "now I see why DJ didn't just use an H-Bridge here. There's only one motor!" Im not an expert here because I havent personally done it. Have you considered doing it as DJ has and just use modified servos? Another option (and again I havent done this yet) is to use a Tamiya dual motor drive and and an H-Bridge. There may be an issue with the shaft length though. Here are DJ's suggestions from this website (Example1 and Example2)
Netherlands
Hi there Jackie,
I''m busy with the u-command also ( bought it very cheap via ebay). Your right about the one motor. I pulled everything out and put 2 modified servo's in it. hope you can see it pictures made with an old camera.
and her under
hey Pabi
any more pics of yur wall-e?
Netherlands
Jup you can find more pictures over Here
