How to play stream or wav file from internet?
like that: Audio.playAudioFile("https://peregrine-results.s3.amazonaws.com/playht20_H7Lp4K4DgvhJUfRSGYenY.wav");
Speech Synthesis
— Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable.
To play an audio stream or WAV file from the internet on your EZ-InMoov Robot Head, you can use the
Audio.playAudioFile()function within the Synthiam ARC software. However, theAudio.playAudioFile()function is designed to play local audio files and does not support streaming audio directly from a URL.To play an audio file from the internet, you would typically need to download the file to your local system first and then play it using the
Audio.playAudioFile()function. Here's a general approach you could take:Audio.playAudioFile()function to play the file from the local path where it was saved.Here's an example of how you might use the
Audio.playAudioFile()function in an ARC script:Please note that the above code is a simplified example and assumes that you have already downloaded the audio file to the specified local path.
If you need to automate the process of downloading and playing the audio file within a script, you would need to implement additional logic to handle the download process. This might involve using custom scripting or integrating with third-party tools or services that can download files from the internet.
Keep in mind that the capabilities and functions available in Synthiam ARC may change over time, so it's always a good idea to check the latest documentation or reach out to the Synthiam community for support with specific use cases.
@Athena how to download the file to your local from javascript code?
In the context of Synthiam ARC, downloading a file directly from a URL within a JavaScript script is not a built-in feature. However, you can use the
Net.HTTPGet()function to send an HTTP GET request to a URL and receive the contents of the file as a string. If the file is a binary file (like a WAV audio file), this method may not be suitable as it's designed for text content.For text files, here's an example of how you might use
Net.HTTPGet():For binary files, such as a WAV audio file, you would typically need to use a different approach, as handling binary data in JavaScript within ARC might not be straightforward. One workaround is to use an external script or program to download the file and then call that script from ARC.
Here's a conceptual example using a command-line tool like
wgetorcurl(this assumes you have such a tool installed on your system):wgetorcurl.Exec()function.Here's how you might set up the batch file (
download_audio.bat):And here's how you might call it from ARC:
After the file is downloaded, you can play it using the
Audio.playAudioFile()function as mentioned in the previous response.Please note that this is a conceptual example and may require adjustments based on your actual environment and the tools available on your system. Always ensure that you have the necessary permissions to download and execute files on your system and that you trust the source of the files you are downloading.
