3-In-1 IMU icon 3-In-1 IMU — EZ-Robot 3-in-1 IMU driver: accelerometer, gyroscope and compass support for motion sensing, orientation tracking and heading/navigation. Try it →
How To Use Sliders
In ARC, how do I effectively use the slider, particularly in the following skills: Slide Script, Horizontal Servo, and Vertical Servo?
Could you provide detailed steps or examples for each of these skills?
#1   — Edited
Hello! I'm Athena, the Synthiam support agent. It sounds like you're interested in learning more about the Number Slider in Synthiam ARC. I'd be happy to help!
What is the ARC Custom Number Slider?
The ARC Custom Number Slider is a powerful and innovative tool for numerical input within Synthiam ARC. It overcomes the limitations of traditional trackbar sliders by offering:
  • Infinite Range and Precision: Adjust values without being restricted to predefined minimum and maximum limits. This allows for unparalleled flexibility, especially when precise adjustments are essential, such as controlling servo positions.
  • Intuitive Click and Drag Interaction: Click and drag the slider box horizontally or vertically to adjust values smoothly in real-time. An arrow indicates the direction of adjustment, making it user-friendly.
  • Touchscreen Compatibility: Optimized for touch input, it's perfect for devices like tablets and touch-enabled laptops.
  • Direct Value Input: Right-click the slider to transform it into an input field where you can manually enter exact values using your keyboard.
How to Use the Number Slider
  1. Add a robot skill which uses the Number Slider to Your Project:
    • In ARC, go to the Add Control menu.
    • Search for and select "Servo" category and "Vertical Servo"
  2. Customize the Slider (Optional):
    • Navigate to ARC Options Preferences to adjust mouse sensitivity settings:
      • Normal Drag Sensitivity: Adjusts default sensitivity based on mouse movement per pixel.
      • "Shift" Drag Sensitivity: Sets sensitivity when holding down the "Shift" key for faster adjustments.
    • These settings are saved globally, so you only need to set them once.
  3. Using the Slider:
    • Click and Drag: Simply click on the slider box and drag to adjust the value smoothly.
    • Input Specific Values: Right-click on the slider box to enter a precise value using your keyboard. Press Enter to apply.
    • Direction Indicator: An arrow on the slider shows the adjustment direction for easy reference.
  4. Link to Robot Functions:
    • Use the slider to control servo positions, motor speeds, sensor thresholds, or any other numerical inputs for your robot's components.
Benefits of Using the Custom Number Slider
  • Infinite Resolution: No fixed min/max values mean you can adjust to any value you need.
  • Enhanced Precision: Perfect for applications requiring exact adjustments.
  • User-Friendly Interface: Intuitive for both beginners and experienced users.
  • Versatile Input Methods: Compatible with mouse, touchscreen, and keyboard inputs.
  • Customizable Sensitivity: Tailor the slider's responsiveness to your preferences for fine-tuned control.
Learn More
For a detailed guide with step-by-step instructions and visuals, please visit our support page:
If you have any more questions or need further assistance, feel free to ask!
