Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
India
How To Use Stepper With Inverse Kinematics
@Athena Im using 2 stepper motors for arm shoulder joint of humanoid robot. elbow joint is servo and other joints are serial servo bus servo motors, how to use in the combination of motors in robot arm?. im trying to controlling VR Hand/Controller movement with inverse kinematics.
Stepper Servo by Synthian Inc.
Control up to 127 stepper motors via Arduinos mapped to ARC servos; supports any stepper driver, serial network, home calibration, speed/accel.
Control robot arms with inverse and forward kinematics, converting X/Y/Z positions into joint motion and reporting end-effector location.
To control a robot arm with a combination of stepper motors, servos, and serial bus servos using inverse kinematics in ARC, you'll need to configure each type of motor appropriately and ensure they work together seamlessly. Here's a step-by-step guide to help you set up your robot arm:
Step 1: Configure Stepper Motors
  1. Add Stepper Motor Control: In ARC, add a stepper motor control for each stepper motor you are using. You can find stepper motor controls in the "Add Control" menu under the "Stepper" category.
  2. Configure Stepper Motor Parameters: Set the parameters for each stepper motor, such as steps per revolution, speed, and acceleration. Ensure that the stepper motors are correctly wired and connected to the appropriate ports on your controller.
Step 2: Configure servo Motors
  1. Add servo Control: For the elbow joint and any other joints using standard servos, add a servo control from the "Servo" category in the "Add Control" menu.
  2. Set servo Parameters: Configure the servo parameters, including the port, min/max positions, and any necessary inversion.
Step 3: Configure Serial Bus Servos
  1. Add Serial Bus servo Control: For joints using serial bus servos, add the appropriate serial bus servo control from the "Servo" category.
  2. Configure Serial Bus Parameters: Set the ID, baud rate, and other necessary parameters for each serial bus servo.
Step 4: Integrate with Inverse Kinematics
  1. Add Inverse Kinematics Control: Add the Inverse Kinematics Arm control from the "Add Control" menu under the "Inverse Kinematics" category.
  2. Define Arm Structure: In the Inverse Kinematics configuration, define the structure of your robot arm by adding joints and specifying the type of motor (stepper, servo, or serial bus servo) for each joint.
  3. Set Joint Parameters: For each joint, specify the length, offset, and type (rotation or lever). Ensure that the parameters match the physical configuration of your robot arm.
Step 5: Control with VR Hand/Controller
  1. Add VR Control: If you want to control the arm using a VR hand/controller, add the appropriate VR control from the "Add Control" menu under the "Virtual Reality" category.
  2. Map VR Movements to Arm: Use scripting or control commands to map the VR hand/controller movements to the inverse kinematics control. This may involve converting VR coordinates to the X, Y, Z coordinates used by the inverse kinematics control.
Step 6: Test and Calibrate
  1. Test Movements: Test the movements of your robot arm to ensure that all joints are responding correctly to the inverse kinematics commands.
  2. Calibrate: Make any necessary adjustments to the motor parameters, joint lengths, or offsets to ensure accurate and smooth movements.
Additional Tips
  • Use ControlCommand(): Utilize the ControlCommand() function to send commands to the inverse kinematics control and other motor controls.
  • Monitor Feedback: If your motors provide feedback (e.g., position or torque), use this information to improve control accuracy and responsiveness.
  • Safety First: Always ensure that your robot arm operates within safe limits to prevent damage to the motors or the arm itself.
By following these steps, you should be able to integrate and control a robot arm with a combination of stepper motors, servos, and serial bus servos using inverse kinematics in ARC. If you have any specific questions or encounter issues, feel free to ask for further assistance!
#2   — Edited
We have moved your question into a new thread because it was unrelated to another thread. Please ensure you post a question to create a new thread when the content is out of scope. In this case, you ask about combining two robot skills to achieve a goal.
  1. Stepper motor robot skill
  2. Inverse Kinematics robot skill
The stepper motor skill will use stepper motors as servos. The servos will be on Vx (virtual ports). The inverse kinematic robot skill will move servos. You would select the stepper motor Vx servos in the Inverse Kinematics robot skill.
  1. Ensure the stepper motor robot skill is working correctly. You can test the stepper motors as servos using a Vertical servo robot skill, select the Vx ports, and move the servo. Once you have achieved this, you can move to the next step.
  2. Add the inverse kinematic robot skill. Follow the inverse kinematics manual to define the robot arm by joints, lengths, and rotational axis. Select each joint servo by the Vx servo of the stepper motors from Step #1. Testing will allow you to use the ControlCommand for the inverse kinematics robot skill or the UI to enter coordinates manually
You can follow the manual for each robot skill that we listed above.
To integrate the Stepper servo and Inverse Kinematics Arm robot skills in ARC, follow these steps to ensure they work together effectively:
  1. Add Stepper servo Control:
    • In ARC, add the Stepper servo control for each stepper motor you are using. You can find this control in the Add Control menu under the servo category.
    • Set the parameters for each stepper motor, such as steps per revolution, speed, and acceleration. Ensure that the stepper motors are correctly wired and connected to the appropriate ports on your controller.
  3. Test Stepper Motors:
    • Use a Vertical servo control to test the stepper motors. Select the Vx (virtual ports) for the stepper motors and move them to ensure they are functioning correctly.
Step 2: Configure Inverse Kinematics
  1. Add Inverse Kinematics Arm Control:
    • Add the Inverse Kinematics Arm control from the Add Control menu under the Inverse Kinematics category.
    • In the Inverse Kinematics configuration, define the structure of your robot arm by adding joints and specifying the motor (stepper, servo, or serial bus servo) for each joint.
    • For each joint, specify the length, offset, and type (rotation or lever). Ensure that the parameters match the physical configuration of your robot arm.
  4. Select Stepper Motors:
    • For the joints using stepper motors, select the corresponding Vx ports configured in the Stepper servo control.
Step 3: Integrate with VR Hand/Controller
  1. Add VR Control:
    • If you want to control the arm using a VR hand/controller, add the appropriate VR control from the Add Control menu under the Virtual Reality category.
    • Use scripting or control commands to map the VR hand/controller movements to the inverse kinematics control. This may involve converting VR coordinates to the X, Y, Z coordinates used by the inverse kinematics control.
Step 4: Test and Calibrate
  1. Test Movements:
    • Test the movements of your robot arm to ensure that all joints are responding correctly to the inverse kinematics commands.
  2. Calibrate:
    • Make any necessary adjustments to the motor parameters, joint lengths, or offsets to ensure accurate and smooth movements.
Additional Tips
By following these steps, you should be able to integrate and control a robot arm with a combination of stepper motors, servos, and serial bus servos using inverse kinematics in ARC. If you have any questions or encounter issues, feel free to ask for further assistance!
