Talk Servo V2 icon Talk Servo V2 — Animate servos to simulate jaw/mouth with ARC text-to-speech; configurable vowel/consonant timing, start sync, multi-servo control, pause/stop. Try it →
How To Use Wheel Encoder From Blockly
I have a 2 wheeled robot running the EZ-B V4.     The EZ-BV4 is driving a PWM Hbridge.  Each wheel has an encoder counting the wheel pulses using an Arduino Mega 2560.   My question is how can I command my robot to move a specified distance stop, and then turn 90 degrees and move another distance stop etc.
I assume I can feed the distance into the Mega2560 via Blockly, but I'm not finding the Syntax to do this.
i.e  move forward 6 feet
  1. Set motor L and R motors to PWM 50% 2.  Load 1000 clicks into Mega 2560 odometer counter,  ( can I do this via UART ? ) 3.  Robot moves until one of the 2 counters hits 0, then motors stop
Goto next routine. rotate platform 90 degrees right
  1. Set motor L PWM to 50% and  reverse R to PWM 50%
  2. Load 450 clicks into Mega 2560 odometer counter,
Arduino UNO wheel encoder: reads left/right ticks, provides counts, configurable ticks, wheel & pivot sizes, optional pose telemetry to ARC NMS.
Thanks dj this has been resolved
