EZMQTT Broker icon EZMQTT Broker — Local MQTT broker for ARC: host pub/sub messaging on TCP port 1883, relay topics between publisher and subscriber clients. Try it →
Technopro, you probably can't run it on port 80 because there is already a web server running. Check your DEBUG message when STARTing the http server
Czech Republic
To DJ Sures: At the same moment when I type ip address of http server and then push enter. OK I will reinstall EZB.
The latest version of ARC contains more detailed logging information - perhaps that will help identify the issue with your installation.
Czech Republic
Log after stop of finding http server is: 28.10.2014 11:20 - HTTP Error: System.OverflowException: Pro typ bajt bez znamenka byla hodnota bud prili velka, nebo prili mala. v System.Convert.ToByte(Char value) v System.Linq.Enumerable.WhereSelectEnumerableIterator2.MoveNext() v System.Linq.Buffer1..ctor(IEnumerable1 source) v System.Linq.Enumerable.ToArray[TSource](IEnumerable1 source) v .() v ?.(NetworkStream , , Int32 ) v ?.(NetworkStream , , String ) v ?.(Object ) URL: /, Header: GET / HTTP/1.1 Accept: text/html, application/xhtml+xml, / Accept-Language: cs-CZ User-Agent: Mozilla/5.0 (Mobile; Windows Phone 8.1; Android 4.0; ARM; Trident/7.0; Touch; rv:11.0; IEMobile/11.0; NOKIA; 909) like iPhone OS 7_0_3 Mac OS X AppleWebKit/537 (KHTML, like Gecko) Mobile Safari/537 UA-CPU: ARM Accept-Encoding: gzip, deflate Host: 192.168.2.10 DNT: 1 Connection: Keep-Alive
, Path: /, IP Address: 192.168.2.7
and in the phone Explorer message is written: Unable to find server or DNS issue
Czech Republic
and from another Windows 8.1 computer:
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: 28.10.2014 11:28 - TCP Server stopped 28.10.2014 11:28 - TCP Server stopped 28.10.2014 11:28 - TCP Server stopped 28.10.2014 11:28 - TCP Server stopped 28.10.2014 11:28 - TCP Server stopped 28.10.2014 11:28 - HTTP Error: System.OverflowException: Pro typ bajt bez znamenka byla hodnota bud prili velka, nebo prili mala. v System.Convert.ToByte(Char value) v System.Linq.Enumerable.WhereSelectEnumerableIterator2.MoveNext() v System.Linq.Buffer1..ctor(IEnumerable1 source) v System.Linq.Enumerable.ToArray[TSource](IEnumerable1 source) v .() v ?.(NetworkStream , , Int32 ) v ?.(NetworkStream , , String ) v ?.(Object ) URL: /, Header: GET / HTTP/1.1 Accept: text/html, application/xhtml+xml, / Accept-Language: en-GB,en;q=0.7,cs;q=0.3 User-Agent: Mozilla/5.0 (Windows NT 6.3; WOW64; Trident/7.0; Touch; LCJB; rv:11.0) like Gecko Accept-Encoding: gzip, deflate Host: 192.168.2.10 DNT: 1 Connection: Keep-Alive
, Path: /, IP Address: 192.168.2.17 28.10.2014 11:28 - HTTP Error: System.OverflowException: Pro typ bajt bez znamenka byla hodnota bud prili velka, nebo prili mala. v System.Convert.ToByte(Char value) v System.Linq.Enumerable.WhereSelectEnumerableIterator2.MoveNext() v System.Linq.Buffer1..ctor(IEnumerable1 source) v System.Linq.Enumerable.ToArray[TSource](IEnumerable1 source) v .() v ?.(NetworkStream , , Int32 ) v ?.(NetworkStream , , String ) v ?.(Object ) URL: /currentsetting.htm, Header: GET /currentsetting.htm HTTP/1.1 Connection: Keep-Alive Host: 192.168.2.10
, Path: /currentsetting.htm, IP Address: 192.168.2.17
Czech Republic
Does nobody know what is wrong ?
Trinidad/Tobago
Twitter YouTube
#15
Are you typing in the ip address on the tablet/computer with the correct port after you've changed it in ARC?
For example: 192.168.2.17:8080
Czech Republic
#16
Yes, I tried everything. I changed ports in router too and I had tried once more with another ports incl. default port :80
