Good Morning,
I would like some assistance with the setting up the HTTP_Server Command - that points to a Virtual Desktop, that acts like a Static WebPage, Is this possible?
Thanks Wayne
Ultrasonic Distance
— Displays HC-SR04 ultrasonic distance readings in ARC; scriptable via GetPing(), pausable, sets a variable with multiplier, optional NMS output
Good Morning,
Thanks Wayne
Ok. I will post the code tomorrow morning when I get to the office.
Thank You very much.
@thetechguru
Good Morning.
Here is the code that I wrote for the program.
Any and all help that could be done would be most appreciate.
I know in the other forum post the code was cleaned up by other users. I need to take the time and work on that.
As long as the variable names stay the same, it should be pretty easy to make a web page. If DJ doesn't respond by the end of the day to my question about Custom HTTP syntax for displaying variables, I'll start looking into an alternate way to do it that would work either in Custom HTTP or any other web server.
Thanks for all of your help so far.
Last night on my flight I made changes to the http server to display variables and digital port status. I'll update ARC either this evening or tomorrow with the changes.
@DJ. Wow! That is awesome! Thank You!
@DJ Thanks much. Saved me a lot of head scratching too..
@DJ Thank You
