Netherlands
Resolved Resolved by rickymahk2013!
Humanoid Project Full Scale
Hi ,
i want to build a humanoid robot , that walk on 2 legs. i , figure i need strong servo´s that provite the weight. because my humanoid robot become about 190 cm high. but i not sure if i can use normal servo´s from the EZ-b developer kit. i think that is to weak to suport movement. also i want build a accu 12 volt or 24 in it. so he have power on is onw while. I hope someone can help me.
regards Michael
#41
Did you follow the directions given in the links? It seems you have a language issue with your version of windows. You need to change the decimal from a comma to a period:
Decimal Change If you receive the error, this is because your culture is not set to use a Period as a decimal separator.
Visit the Control Panel -> Region -> Additional Settings -> Change decimal from a , to .
Netherlands
#42
Thanks for the help;) its working. now i can start programming;)
What did you do that rickymahk2013 helped you resolve?
#44
@Dave Schupius
The thread was marked resolved a month ago when rickymahk2013 recommended some motors. Unrelated to the latest problem with the OS Locale settings.
Netherlands
#45
rickymahk2013 helpt me out whit strong servo's. also he helpt me whit order the servo's.
Unfortunately, you can select one person who helped you at that time. all who have helped me earn the same tittle (you Helped resolve) I've generally everyone thanks for the good help.
Netherlands
#46
my ez-b software is now good. I wanted to run a test. with my servomotor, but that was not good. because I could not find ez-b v4, WiFi in the list of the ARC software. my computer was able to find the wifi of the ez-b v4.
Your ezb4 is still in AP mode... You can't use the scan tool for it until you put the ezb4 in Client mode..... Take this lesson EZB connection modes then the next one too...
Netherlands
#48
according to the website, I must click the round icon
when I do, I end up here.
it should actually be this. at least I think.
Perhaps I miss something. I just do not know what it is.
