Robotis Openmanipulatorx icon Robotis Openmanipulatorx — Inverse kinematics for Robotis OpenManipulatorX: compute joint angles and MoveTo 3D (cm) positions, supports camera-to-CM mapping for pick-and-place. Try it →
Norway
I Am Unable To Connect To Your Network
I was in the process of trying to calibrate JD and stumbled across the web interface to the controller. From there I configured my network and it failed. When JD rebooted, he/she says "I am unable to connect to your network".
Is there a way I can reset JD to factory defaults to recover from this?
Thank you.
There is a lesson in the learn section for resetting your EZ-B.
Lesson
to reset it, push the little button on the top left of the ex-b V4.
