Joystick (Xinput) icon Joystick (Xinput) — XInput joystick skill for ARC: maps Xbox controllers to movement, servos, triggers, vibration, variables; supports analog inputs and scripts. Try it →
@161019.
I might have found why you are having your issue. While trying to debug an unrelated issue on a windows 7 laptop I've still got laying around, I updated ARC to the latest version and started to get the same message as yourself (and I deffo have a sound card installed;))...
The "pandorabot control" responded but the "speech recognition control" did not. How I fixed it was to change the "Language" in the speech recognition config menu from en-GB to en-US, saved the new settings then closed the ARC project. When I re-opened the project again the recognition loaded successfully (with no error message this time) and the voice recognition control worked again.
Hope that helps in some way.
