Lidar-Lite Laser Module icon Lidar-Lite Laser Module — Laser Lidar-Lite ARC control reads distance, velocity and signal strength (0-40m+) via EZ-B v4 i2c, setting EZ-Script vars for robotics Try it →
Thank you so much I appreciate it :)
Note: these extender cables are commonly available at any hobby store that services the R/C community. If you are ordering items from EZ-robot anyway, then add them to your order, but the tracked shipping from EZ-Robot is too expensive for a $2 commonly available part. You aren't taking money out of EZ-robot's pocket by doing that. They sell these kinds of parts as a convenience to their customers, not as a profit item.
Has anyone actually made their JD taller and walking gaits function successfully / correctly ?
These thoughts went through my head also, but I decided that trial and error is the mother of learning and decided that I would just answer the question as I interpreted it.
I seriously doubt that what he is trying to do will work. servos have a certain strength and the further you get from the servo, the higher the strength that is needed. When you add in the weight of the servos along with the distance that the servos are from one another, I am pretty sure that you would ultimately come to the point that the robot wouldn't be able to move its upper servo, and thus not be able to move its leg forward or backward. He may have some design that he isn't sharing but I suspect that he will run into issues.
I'm trying the same thing, my plans include 5 servos per leg (foot, ankle, knee, thigh and hip) and 4 for each arm. Also a pan and tilt for the head and thinking of including the same for waist. But, legs first, then arms. Just need get the cash flow to buy servos.
oh okay :) how is it going so far
I would add the 4in1 sensor so that you can have some scripts running to detect if it is falling over and move to a known stable position or stand back up.
